Change the color of the X,Y,Z coordinate system
Good Afternoon,
Is it possible to change the color of the x, y, z coordinate system.
Thank you
Greg
Once you have create a coordinate system you can RMB and...
PLM World Member Genius PLM World Member Genius
Once you have create a coordinate system you can RMB and choose edit definition.
You will then be able to redefine the Coordinate systems to a new location
That was for traditional
For synchronous one, select and use the steering wheel
You can move coordinate system from trad to sync
