Change the "last author" call
Heyo!
I'd like to put only mi initials in the last author call. Any idea about how change it?
Thank you!
Betreff: Change the "last author" call
Hi @BeatrizSeoane
besides changing Your system name IMHO there is only a solution via API (programming) which will lead to a result.
Wolfgang
Hi @BeatrizSeoane
just have written a small macro for changing the LastAutor property
Wolfgang
Omg Thank you!!
It is so usefull!!
Hi @BeatrizSeoane
welcome!
It really is a quick small macro without any intelligence, but it does its job.
First I thought about using an INI/XML file for translating system user names to small initials.
Maybe I will find that time
But this will be no promise so far
Wolfgang
Hi Wolfgang,
I'm trying to get this macro to work but whenever I input my initials and click Set Last Author it does not do anything and does not change the author in the drawing. Am I doing somthing wrong?
Thank you in advance!
@hawcad
Sorry I'm still new so I didn't know I had to tag when replying
Hi @IgorP
Can you check the 'Last saved by' value under the Statistics tab. This is the value the macro changes.
~Tushar Suradkar
fb.pngSolid Edge Users Facebook Group - Let's Sync
Hi @IgorP
the macro just does what it is intend to do.
It changes the LastAutor property of the current document
Wolfgang
I think I am in a Catch22 situation with using the macro. I want to send out a part file with last name changed to "Tushar" while I am logged in the computer as something else, say "XYZ". The macro lets me change the last used author to "Tushar", but before giving out the file I want to save it first which changes the last used author back to "XYZ" since I am logged in as "XYZ". If I choose to not save the file I cannot retain the changed author as "Tushar". Have I understood the macro wrong or using it incorrectly ? Thanks. Tushar
