Changing size
Not applicable
Is there a way to increase or decrease the size of a drawing by a few percent? Let us say I make a casting and then find I need to make a small change to the overall size of the part can I do that? Can I change the intire drawing at one time.
Re: Changing size
There is a Scale command under the Mirror command in the Drawi command group.
Rick B.
