Changing template of an existing draft
hello,
i have a draft that already has a template, i'm trying to update the template but when I replace the
background with the new template the custom properties of the new template doesnt show on file properties,
do you any know how to this??
i dont want to add them manually because ( about 40 properties)
thanks in advance.
Betreff: Changing template of an existing draft
Hi @roberto940921
what was these fields referred to?
Can You show the original property entries?
When I have done a Backround Change (what You refer as Template Change and I hope I have understand it correctly) all used property text fileds will be reflected correctly.
Wolfgang
