Circular Pattern WIth Steering Wheel
I have a synchronous part with a flat on one side of a cylinder. I want to copy the flat symmetrically to the other side of the cylinder. I tried steering wheel on the axis and then ctrl -left clicking the torus to make a 180 deg copy but it won't work.What am I doing wrong?
Thanks for ny help
Walter ST10 Win 7 Ultimate
Quadro k4200
7 REPLIES 7
Re: Circular Pattern WIth Steering Wheel
Hi there @wbrokow1,
Is there any reason you could not just to use the "Circular Pattern" command to achieve this?
Solid Edge 2019 [MP8] Classic [x3 Seats - Cloud Enabled]
I get an error : error detected no pattern created
Quadro k4200
mirror worked but pattern didn't.
Why?
Quadro k4200
when I use solid cylinder & b ox to make the flat , then pattern works
Quadro k4200
I think you are doing it correctly but select the flat and the square shoulder then it works with synchronous.
Franz
Yes, That's it ! Thanks
Quadro k4200
@wbrokow1 Please mark one or more answers (not one of yours) as a solution.
Bruce Shand
