Claims sketch not fully constrained, but it is
(view in My Videos)
Currently I'm dealing with a feature with multiple holes, and it keeps telling me it isn't fully constrained in the pathfinder.  When I go back in, some of the holes will show up as blue indicating they aren't, but they are. If I click and drag one of the holes then they all turn back to black, but when I exit the sketch it goes back to pretending it's not fully constrained. I know I can just move on, but I'm a stickler for things like this, and I know it's fully constrained. Anyone else ever have this issue?
Solid Edge 2019
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
Re: Claims sketch not fully constrained, but it is
Hi there @nominus38,
Not really come across this before, but...... is it possible there are duplicate holes at that/those locations?
Nope. Sorry.  And I've had things like this happen before, but usually it goes back to normal after I do a click and drag. Only one other time I can think of where the pathfinder kept saying the sketch was underconstrained however.
Solid Edge 2019
Oh darn....worth a shot......speaking of, have you had enough coffee?
Maybe some spilt beyond the cup holder.  Robot LOL
Did you have a look with the relationship assistent?
With it you can see where it is underconstraint:
relationship assistent  at 1:12
https://www.youtube.com/watch?v=f4Kgg4DsPDg
Yes, I tried that. It says 0 relationships are required.
Solid Edge 2019
It often happens to me too.
More often with "complex" geometry like an hexagon
Could you post the sketch? Then we can have a look
Don't know how I could post just the sketch. I'd need to post the entire model, which I cannot do in this case.
Solid Edge 2019
Save as and delete everything else. You could also report it to your VAR
