Close Parallel Connecting points
I would like to close the connecting points as well as the parallel lines in this image.
I got the dimension closed, but not the connecting points.
http://screencast.com/t/JKVlYCUu
Greg
Re: Close Parallel Connecting points
The picture is not clear. What connecting points do you want to close?
-Dylan Gondyke
This image will help you much easier. I want to hide the yellow connector
corner, as well the parallel yellow lines.
http://screencast.com/t/27EDlUUI9UNK
Greg
The Relationship Handles button, shown below circled in red, toggles the display of relationship handles on and off.
-Dylan Gondyke
