Collecting ideas for blog topics
MLombard
Retired
I haven't done this in a while, and as I'm starting to run low on What's New topics, I thought I might ask you all about some things you'd like to see a blog article on. Generally technical stuff would be best, or administration type (best practice) articles. Maybe there's a st10 topic you'd like to dig into a little deeper. So what sort of blog articles would you like to see?
Thx,
Matt Lombard
Re: Collecting ideas for blog topics
I always lean towards those niche features that fall out of site to most users but could be quite useful.  Some suggestions are:
  • Zero-D (Virtual Components workflow)
  • Frames
  • Schematics (Draft Blocks and Connectors)
  • Inter-Part Copies
  • Clipping Planes
  • Styles Manager
  • 2D only Draft workflows
  • Block Libraries
  • Systems Libraries
  • Feature Libraries
  • Detach/Attach faces
http://Grundey.blogspot.com
Hello~
I am most curious about the following.
1. Thickness change parts of synchronous and sheet metal (inside the material, not outside the material)
2. Synchronous performance
3. DWG file direct paste
4. Are there any things to improve performance?
Hi @MLombard
I would like to see more instructions ( features / commands ) / training posts / videos.
Related to : Large assemblies, Modelling, Frames, Surfaces, Drafting - but only in Ordered Mode.
Arek
A current topic for us would be how to add custom parts to the standard parts library and make them available in the fastener system
One that goes out of date rather quickly but could be useful would be a hardware comparison using ST10.
For many people/companies investing in hardware is seen as a big cost. Knowing where to put your cash would be useful. So for example where spec of laptop would best suit Solid Edge, what desktop configuration and now maybe even tablet devices. It would be interesting to have some performance comparisons for working with different size assemblies or complex drafts. Working local v over network etc. Lets face it most CAD demos are set up to look and work as slick as possible so as to wow customers. They're often not what most of us deal with day to day.
Guy
CAD/CAE Manager
ST8 MP12
Honored Contributor
Honored Contributor
My daily fight is sheet metal corners. Lessons adressing the limits of 2 way and 3 way corners would have helped me tons the first year of use. Understanding what is impossible is the main thing.
Following on from @Guy_H77 - how about one on how to get the standard parts library installed correctly in the first place !
HP Z420 16GB RAM
Quadro K4000
ST10 MP12 on Windows 10 Pro 64.
Hi Matt,
I would like to see more on:-
  • Frames - Coping detail view in draft.
  • Design Manager work flow (revisions, file locations and file/part status)
  • Part and Drawing numbering best practice using SE
Something frustrating for me. Don't know if it is me of SE/Keyshot, but a how-to on how to change/copy assembly's and still keep the assigned materials in Keyshot would be a huge help.
Solid Edge 2019 & AutoCAD 2019 user
It would be great an article about 2D schematics, blocks with properties and BOM of them.
I find difficult everytime and I end up to duplicate blocks for each dimensions instead of a correct us of properties.
