Color for non-stitched edge of a surface
Is there a way to make change the default color for a non-sitched edge of a surface from the green to something like red?
Peter Smith
ST9
Re: Color for non-stitched edge of a surface
Settings - Options - Colors - "Selected" color is what I think you are looking for; BUT be advised this will apply everywhere that the "Selected" color is used throughout the UI.
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
Got it....Thats does make the change, but I was hoping to would be isolated to the non-stitched edges...
Thanks.
Peter
