Color library wrong diplayed
Hi everybody,
I've a problem on the new solidedge2019 about the colors.
I want to define colors in my assemblies because when we finish a project we color it and send it to our customer to make it validated.
So in my template, I saved colors. For the RAL ( steel paint ), i've found a solution because we can use RGB but for the wood I need to link a texture even for some specific paints.
After done it, there is a display problem I think that is because our linked pictures are on a network ( yes, I need color to be common on each computer of my company .. spain, turkish, China ..).
Find attached a screenshot of my problem, ( on it, i've done the RAL with pictures I downloaded on their website)
thank you in advance if you've already seen and resolve that problem Smiley Happy
Vincent.
3 REPLIES 3
Re: Color library wrong diplayed
Hi @mc-laren
I found that an er exists for this issue unless it has been solved already or a workaround exists:
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Save-Textures-in-Solid-Edge-file-ER...
Tushar
Hi @Tushar ,
Thank you for your answer. So no solution for the moment ... Smiley Sad
Could you create an ER about that, because it's clearly a wasted time for us. Each time we need to apply a texture in an assembly we have to do "view/faceOverrides/Texture → then go to find it on our network ( I estimated 2hours of development lost per week).
Thank you  very much,
Vincent
Hi Vincent,
Either you or your reseller has to file an ER.
Tushar
