Colours in assemblies & parts
Having managed to apply colours to parts at the assembly level, now I cannot find how I did it - no styles tab is visible etc - nor how to remove those colours.
I can use part painter at part level, I can disable the assembly overrides in Colour Manager, but switching to Keyshot, those assembly colours are still there, and I'm stuck with them!
I'm on ST10
Re: Colours in assemblies & parts
Hi
Is it 'Face Styles' in the Style menu that you need? If you click on a part and then select the option required on the 'Face Styles' dropdown.
585 ST9 Win 7
Feasibly, though I don't see any way of applying or removing face styles from the assembly?
If you select the part you want to changing (by clicking on it) and then use the drop down on the Face Style command, you can select between None, Use Part Style, or one of the colours from Styles.
585 ST9 Win 7
Thank the good lord above, that's done it Smiley Happy
