Comment utiliser la feuille modèle 2D ?
N/A
Bonjour,
Utilisateur débutant, je ne comprends pas quand, pourquoi et comment utiliser la
feuille "modèle 2D" !
Merci pour votre aide, Marc
Beginner user, I do not understand when, why and how to use the sheet “2D models”!
Thank you for your assistance, Marc
MSA
Re: Comment utiliser la feuille modèle 2D ?
N/A
Marc,
You use 2D Model when you want to draw at 1:1 scale and your geometry is
either too small or too large to display on a standard size drawing.
For example: You want to draw your house at full scale. The geometry is too
large to fit on a standard drawing at full scale.
There is a topic posted to this news group called "Scaling large objects".
Scroll down in the list of topics and expand this topic. I have posted a
reply to the topic that contains a document that describes the uses of
scale. I believe you fill find it informative.
Rick B.
N/A
"Ricky Black" wrote:
>Marc,
>Regards,
>Rick B.
OK, Merci beaucoup ! Thank you !
Marc
MSA
