Configuration Conversion
What is involved in converting cfg. File from a external hard drive to an sync. or assembly
Greg
There is no physical design data in a configuration file....
There is no physical design data in a configuration file....these only contain a data base of the way the contents of the "assembly" itself is configured and user defined display states.
So to answer to your question.....there is no way to get a model from a *.CFG file.
Testing: Solid Edge 2019
