Configuration File Usage
I have quite a few assembly groups in assembly. Is the configuration file with settings set to a folder. The reason I ask is... While I opened the flash drive originally, all the doc were a cfg.file.
Configuration files are typically best left to reside alo...
Configuration files are typically best left to reside alongside the parent assembly file[s].
Solid Edge ST10 [MP8] Classic [x2 seats]
