Constraints - pathfinder inquiry
Hi Edgers,
I am facing some dilemma,
how to find out what constraints are responsible for ''driven'' icon as shown in the attached picture :
I have got an icon: Driven by Top Tool 01, and I presume this is only information for a user.
But how to get more information about this and/or delete this constraint/link.
thank you,
Arek
4 REPLIES 4
Re: Constraints - pathfinder inquiry
I assume there is an inter-part relation here.   take a look at your links collector and see if that helps shed any light for you...
Matt Johnson
Solid Edge Certified Professional
Solid Edge 2019 (SEEC) - Production
NX12 (Tc Integration)
Teamcenter 10.1.7
Hi @Johnson_BigMatt,
thanks for quick reply.
Can you please be more specified and tell me some about links collector ?
thanks.
Arek
Hi @Johnson_BigMatt
I presume you mentioned to Inter Part Manager, if yes, now I understand.
thank you,
Arek
@arekkul
if you see that a Part in your assy has a link...
then you can open that part and investigate further to see what is linked and what feature of the part has the link.
so therein I believe you will find why your relationship PF shows a "driven from" reference
or,  as you found...   interpart manager will show you the inter part links...
Matt Johnson
Teamcenter 10.1.7
