Construct Sweep, Loft Command
With this document is the geometry to complicated to do a sweep, loft.
http://screencast.com/t/bc7asFVLip
Thank You
Greg
Re: Construct Sweep, Loft Command
Without knowing what kind of "path" you want to "Sweep" or "Loft" to, it's a bit difficult to say exactly....but I suspect your leaf detail would create "self intersecting" geometry crashing the process.
Solid Edge 2019 [MP8] Classic [x3 Seats - Cloud Enabled]
