Contoured flange to plane
Honored Contributor
Honored Contributor
Is there any way to have a contoured flange's " FiniteDepth" snap to an assembly plane?
In my case, the part is the first part of an assembly, so no other parts exist yet to relate the extrusion length too.
Re: Contoured flange to plane
without testing...  did you try Shift+Select to try to select the plane?
Matt Johnson
Teamcenter 10.1.7
Honored Contributor
Honored Contributor
The selection properties for a contoured flange only have options that snap to endpoints, mid points, etc. That's what I am trying to work around. The Shift Select does not allow me to grab an assembly plane.
Hi @12GAGE
this is a very easy to approach task if - and I mentioned that very often in the past - if You are using Coordinate Systems rather than Reference Planes.
Create Your references in the assembly with using CS and everything works proper fine and exactly as You are requesting
See 2 pictures before and after changing this CS
Wolfgang
