Control over width of letter in text command
Engraving problem
I am unable to get the required width of letter (1.5mm) without increasing the text size.
There is limitation of space available to place this text.
This model will later be used in Nx cam for machining and have to use 2mm cutter for engraving.
Kindly help
Ashish
