Convert inch dimention to mm dimention can not change dislay
Dear all,
I have designed 3D models in inch dimentions and then converted to mm dimentions (model converted to mm) but dimensions displaying unable change to mm display dimention?
Please help me.
Best Regard,
BuiTu
Re: Convert inch dimention to mm dimention can not change dislay
Clicking on the dimention value alow you to change its value. Clicking on the dimention line allow you to change the dimention dimention units.
Yasser
Dear Yasser,
We can not auto change dimention value?
Best Regard,
BuiTu
Hi Bui Tu,
The last step, that youn have to do, is to go to the file properties of your PAR-FILE, the to UNITS, and change MM to IN.
Yasser
Dear Yasser,
Ok, Thanks for your support
Best Regard,
BuiTu
