Re: Convert text to text profile
Do you have the text profile tool (you can search in the command finder)? Is the text created in Solid Edge and with what tool?
/Harri
Here's the tool you should be using. For some reason the text tool creates text that can't be used for extruding etc. Only the text profile tool will work.
I do have this tool but I wanted to convert my texts into profile text wich is impossible (confirmed by digicad support).
This means that I need to recreate all the texts in 'text profile' to be able to extrude them to make them appear on the surface ?!
I'm afraid it seems so. I tried various export/convert to dxf and re-import, but none of the tricks worked. I'll still try exporting to another CAD package and importing back. Sorry about this, I've had the same problem, a "learning experience"..
Ok, Thank you for your awnsers !
I did the long method Smiley Happy
