Converting 3D to 2D
N/A
I'd like to convert a 3D in a 2D drawing.
Does anything know if possible with Solid Edge ST5?
Thanks in advance.
Re: Converting 3D to 2D
Esteemed Contributor
Sure, open the 3D format with Solid Edge and convert it into the appropriate Part or Assembly template, save the file, insert views into a new Draft sheet of the saved Solid Edge model, and then save the Draft sheet to the desired 2D format.
Production: ST10 MP5
Testing: SE 2019
