Converting Part family into PARASOLID form
I was wondering if there is a way to convert the part family (part having different configurations) into PARASOLID in one go. Only way that I know is to  convert the part file hvaing different configuration but belong to same family tree 'one by one' into PARASOLID form.
Re: Converting Part family into PARASOLID form
Since no one has replied to this discussion, So should I assume that what I am trying to do is not possible?
What comes to mind is 'FOP Table/select all members/populate'.
Then run 'batch.exe' that you find under you SE install "Custom"-folder, to convert the parts.
Would this help?
/Ulf
Siemens EMEA GTAC Support
@Ulf_Eriksson
This actually works, Thanks
If you may want to tell me more about Batch.exe file that would be great.
Thank you
