Coordinate Dimensions
Can you uncheck "Connect" under Dimension Lines and set the Terminator Display to "None" by default for coordinate dimensions?  I'm using st4
Re: Coordinate Dimensions
You need to edit the Dimension "Style".  For this to happen in new files as default, you need to make this edit in your template file.  For existing files, after you make the edit in your template, you can go into the Style command and use the Organizer to transfer the modified or new Style to the existing file from the template.
Production: ST10 MP7
Testing: SE 2019
http://Grundey.blogspot.com
