Copy & Paste, change text size
I have noticed since ST7 came out, that the Copy & Paste is changing size of text.
 Does anybody have this problem, what should be done to correct this error...?
Kind Regards
Fernando Cruz
Re: Copy & Paste, change text size
Under what circumstances is it doing this? (Exactly where are you copying from, and where are you pasting to, when this occurs?)
-Dylan Gondyke
Dylan
 I will post here some JPGs showing the original and after.
Kind Regards
´Fernando Cruz
I have been experiencing similar issue with ST9 as original post.
ST9, MP2, Windows 64bit Professional.
This is happening on multipe computers for us.
PDF file attached showing screen captures of examples.
Text Settings changing when copied and pasted.pdf
1st - Text settings dialog box
2nd - Initial copied text & settings
3rd - Field being pasted into, selected to show settings before paste
4th - Field after paste
5th - New text field showing settings before paste
6th - New text field after paste
Draft file template attached
Template file - copy and paste issue.dft
Any suggestions as to root cause of this, maybe a setting in this template file?
Gary Dinges | Mechanical Design Engineer II | Probes & New Product Development Emerson Commercial & Residential Solutions | Therm-O-Disc, Inc.| 1320 South Main Street | Mansfield | OH | 44907 | USA T +1 419 525 8554 gary.dinges@emerson.com
