Reply
Solved! Go to solution
Copy and Paste
Being a little aprehensive on doing something different... affecting a part. Does Solid Edge have a clipboard? Or is it in the computer. Where?
Solution
Solution
Accepted by Grundey (Esteemed Contributor)
‎08-26-2015 04:32 AM
AFAIK every application uses the OS's clipboard.  SE acts...
AFAIK every application uses the OS's clipboard.  SE acts the same way.
If you can be more specifc we might be able to answer in more detail.
But in general yes, you can copy and paste in Solid Edge.
Matt Johnson
Application Engineer
Ally PLM Solutions
matt.johnson@allyplm.com
http://allyplm.com/
