Copy part name to clipboard
I have a need to do this in a Solid Edge asm file. All I want to do is simply copy the text name of the highlighted part to the clipboard. Cant find any answer thru searches, Is this possible?
Re: Copy part name to clipboard
Select the part in pathfinder, press F2 and then CTRL+C.
Thanks but that doesnts work .Smiley Frustrated The clipboard contains whatever it had before.
I found that right click on the part, select Document Properties from the menu, brings up a table, the first column is the part name. Doing this on a top level assembly the table shows all parts in the assembly.
Esteemed Contributor
@kjm  You mean "occurence properties"? Yeah, that will work too but @bweisenberger's method worked fine for me.
Bruce Shand
Honored Contributor
Honored Contributor
Hi @kjm
have You first pressed the F2 button?
This brings You to modify the text from pathfinder, which in my cas is the part name.
CTRL-C copies that to the clipboard.
Wolfgang
Or you can use Assembly Statistics table for this.
BR,
Imics
