Corner Chamfer Question
Does Solid Edge have a corner chamfer type feature?  This would be a chamfer that has three setback distances as shown in Creo...
Matt
Re: Corner Chamfer Question
you could do this
(view in My Videos)
That looks like it will work.  Thanks a lot.
Matt
I think, using SE sync makes it easier.
My suggestion:
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
Hope this helps
Wolfgang
It was already in sync but I used 3d sketch. Same final result.
I tried it in ST5 Synchronous -without 3D Sketch- and it works well!
Solid Edge.. Design better Smiley Happy
Yasser
SO NICELY USED SE SYNC.
I know this is an old and solved question, but this video helps in similar cases:
BR,
Imics
