Crash Log
Good Morning,
I've been receiving these crash logs pretty frequent.  I open a new part etc. Or in the middle of a document Solid Edge crashes.
 http://screencast.com/t/T8ZeLQpIWqN
Thank You
Greg
Greg,   Hard to say what is causing this, but it is usual...
Esteemed Contributor
Greg,
Hard to say what is causing this, but it is usually [not always] a system fault....this can most commonly be related to system memory [RAM] over burdon.
Not much you can do about it [other than upgrade] except for allowing for this in your work flow, by simplifying the data set you are working on at any given time.
Solid Edge ST10 [MP3] Classic [x2 seats]
Re: Greg,   Hard to say what is causing this, but it is usual...
If it happens in only the 3D environments, I have seen this caused by the graphics adapter/driver.
Production: ST10 MP3
Testing: SE 2019
If you have been clicking 'Yes' on the crash dialog to se...
Siemens Genius Siemens Genius
Siemens Genius
If you have been clicking 'Yes' on the crash dialog to send the logs to SE, you can ask for an investigation of your crashes by contacting your VAR or GTAC (depending on where you are and if you have maintenance). The SE development team can then investigate, based on the log files, if your issue can be resolved in code.
Aditya
Aditya Gurushankar
Manager, Solid Edge Planning
