Create 3D
I try to create a 3D from a received 2D drawing but the "Next" button is greyed out.
I thougt it had something to do with the dxf but when I tried to do the same following the tutorial with the original SE files I see the same:
Ay idea?
Solid Edge 2019 & AutoCAD 2020 user
13 REPLIES 13
Re: Create 3D
I just tryed and I have the same problem, ST8 MP6 here, maybe it is broken ?
Re: Create 3D
No problem with ST8MP1
Yasser
Re: Create 3D
You have noticed that in the 'Prompt bar' you see "select elements to define the primary view"?
 /Ulf
Siemens EMEA GTAC Support
Re: Create 3D
I have selected elements to define the primary view but the next button is still greyed out
Re: Create 3D
No, I hadn't. Smiley Embarassed
Re: Create 3D
OK, so solved for Joris but not for Fiorini?
Then I would suggest to log a case with your support, or post your problem drawing here.
Re: Create 3D
It works (as desined by developers Smiley LOL ) well on my ST8 MP6...
Where is your dxf? On the 2d model sheet or on the working sheet?
BR,
Imics
Re: Create 3D
I have created a new empty draft, switch to 2D model, draw a couple of rectangles, run the Create 3D, press next, select one of the rectangle and the next button is greyed out.
I don't need to use this tool now so I wil skip the provess to log an IR
Re: Create 3D
It should be working... Could you record a video about your steps?
BR,
Imics
