Re: Create 3D
(view in My Videos)
Re: Create 3D
No problem with the first version of ST8!
No Maintenance Packs are installed.
Yasser
Re: Create 3D
@Fiorini wrote:
I have created a new empty draft, switch to 2D model, draw a couple of rectangles, run the Create 3D, press next, select one of the rectangle and the next button is greyed out.
I don't need to use this tool now so I wil skip the provess to log an IR
Odd......tried it using the same work flow as you, it seems to be working here.
(view in My Videos)
Re: Create 3D
No problems here. ST8 MP6
(view in My Videos)
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
