Create Planetary gears
I'm trying to create a planetary gear using engeneering reference but it is kinda difficult to control the dimensions of the spurs.
I'v found this example from SW and it looks so easy to define at least the parts:
https://www.youtube.com/watch?v=qVwY6PfwbhY
Anyone know how can it be done using Engeneering Reference i'll be all ears!
Thank you
Re: Create Planetary gears
For real, no one have a clue?
We're apparently on different planets.Man Mad
But seriously it looks like the Engineering Reference has the necessary options to create external and internal spur gears. I would think you could set up a sketch similar to the video in order to mate the gears relative to each other and then apply gear relationships. I haven't tried it though.
Bruce Shand
ST10 MP10 - Insight - Win10 - K4200
