Create Slice Line for Laser in Flat Pattern
Occasionally I want to create a zero thickness line on a sheet metal flat pattern that will be included in the .dxf file created during the "Save As Flat" command that will be used at programming to cut a single line into the sheet metal part.  I have not been able to figure out how to make this happen - is this possible?
Thanks in advance for your help.
Re: Create Slice Line for Laser in Flat Pattern
You can do a Sketch, then create an Etch, and that can show up in your .dxf file.
Thanks, Trike.  That will work.
