Create hole in part based on the geometry of assembly parts?
How can i make a hole/cut in part, based on the geometry of other parts in my assembly?
Re: Create hole in part based on the geometry of assembly parts?
Here watch this: http://screencast.com/t/xHNK1GCjU
Bob
Awesome, thanks a lot Smiley Happy
@BobMileti 's solution is perfect! Smiley Wink
Here is a good to know video, how you can improved yourself if bump into "the wall".
It can be almost "assembly feature", it can be result of subtracting...
BR,
Imics
