Create principal view
Hi. How can I create principal view in code (see image below)?
Origin image I created by code:
ModelLinks modelLinks = _draftDoc.ModelLinks;
ModelLink modelLink = modelLinks.Add(_fullName);
DrawingViews drawingViews = _sheet.DrawingViews;
DrawingView drawingView = drawingViews.AddPartView(
    Orientation: orientation,
    Scale: scale,
    x: StUtils.MillimetersToMeters(x),
    y: StUtils.MillimetersToMeters(y),
    ViewType: PartDrawingViewTypeConstants.sePartDesignedView);
drawingView.CaptionDefinitionTextPrimary = caption;
How to create a second view (see figure below)? Which method to invoke for an object drawingViews.AddXXXXX ?
Re: Create principal view
Hi:
Click the link below to post the question in the Developer forum:
http://community.plm.automation.siemens.com/t5/forums/postpage/board-id/SEDeveloperForum
To answer your question, here are links to in-depth tutorials that show how to create principal views:
using VB.Net
using CSharp
~Tushar Suradkar
www.CADVertex.com
