Created 3d
 I want to create 3d from a 2d drawing, I can get upto the importing of dwg file. But when i get to create 3d option i cannot select the any of the view.
 I saw many videos on youtube about it, i did follow them but still i couldnt get to select the view.
Kindly help.
Thanks and Regards,
Ashish Sarode
Re: Created 3d
It seems it is a block or a group. You should be using Unblock command or Ungroup command!
BR,
Imics
Re: Created 3d
Hi @iashishsarode1 is your problem solved ?
Re: Created 3d
Hello Sir,
I still didnt get the answer for my problem. Kindly help.
Ashish Sarode
Re: Created 3d
Hello Ashish, Did you not understand the answer by Imics ?
Post a picture or video.
Re: Created 3d
Can you upload the file?
Brian Fritz
ST10 latest MP
Re: Created 3d
I cannot upload it.
I had created a simple shaft, placed front and side view in draft. I saved it as .dwg. And now trying to create 3d from this file.
This was my procedure.
Re: Created 3d
When you exporting your draft to dxf, don't use "Translate drawing views as blocks" option. If you use it then you have to use Unblock command!
Here is a short video:
BR,
Imics
