Creating A 60° With A Different Outlook
I was done with revolve so, I thought! With this video I am attempting do a revolve with this 60° arch. I tried a straight approach no luck. I need to wrap with the arch.
http://screencast.com/t/HOuTMUw7tMZk
Thank You
Greg
Re: Creating A 60° With A Different Outlook
Esteemed Contributor
Really can't see what you're trying to do exactly....maybe rotate the view to see where the elements are situated.
I'll take a wild stab at it though....try using "symmetric" extent to 60°.
SWEEP?   I beleive you are trying to Sweep the "cross sec...
SWEEP?
I beleive you are trying to Sweep the "cross section" along the 60 dec arc's "path".
Matt Johnson
Application Engineer
Ally PLM Solutions
matt.johnson@allyplm.com
http://allyplm.com/
If you want to use revolve, you need to set the revolve a...
Community Manager
If you want to use revolve, you need to set the revolve axis to be the CENTER of the arc. If you don't use the center of the arc, then it will not follow the arc.
Dan Staples
