Creating Dinples
N/A
I am in the syn sheet metal trying to build a dimple... studied the tutorial for the dimple. Striking out!
http://screencast.com/t/CbhEPjuBzH
Crousie
Re: Creating Dinples
Crousie,
It looks to me, like your part is not a "normal" sheetmetal part.....looks like there is a circular protrusion below the rectangular one.
This is most likely your first obstacle here.....correct that to a single thickness form, and you should be able to proceed.
I use these dimple features quite a bit....I have attached a sample sheet metal part for your interest.
Solid Edge ST10 [MP7] Classic [x2 seats]
