Creating a Cavity in a Part
N/A
2 Questions: What is required to create a cavity in a part Also, I've been holding down the shift, ctrl key to move rotate ect. Is there a shortcut to hold down these keys and locking? Moving these part a warning pops up (Cannot move both Ordered and Synchronous Parts) This is why the holding down shift, ctrl.
Crousie
Re: Creating a Cavity in a Part
N/A
Crouse,
Explain in more detail your cavity...
you can cut a cavity into the part, revolve the profile creating the exterior and cavity at the same time, you can boolean subtract constructions to creat a cavity...
More detail is needed here.
N/A
Matt,
Sorry for the delay for your question. This is a short video on what I started, the extruded piece of the part I would like to create a cavity... not the whole piece. The outer incomplete unopened part is used at a later step. I checked the help on Poolean operation was inconclusive to me.
http://screencast.com/t/C6wSXTww
Crousie
N/A
I believe you might be looking for the "thin wall" command.?
http://screencast.com/t/Q3kDe2IigWpr
N/A
Matt,
Thank you for the video... I found it quite instrumental in building these parts. My question to you is, How to install the top of this video?
N/A
I assume you are asking how to have the "promt bar" at the top of the display?
your prompt bar by default is at the bottom of the graphic window.
I recomend user drag it to the top for better awareness.
simply click on it and drag it up, when the docking arrows show drop over the main arrow up...
I hope this is what you are asking?
let me know...
N/A
My Bad, I should of been more clear! with the video you sent about the thin wall... I have that done and I want to put a top on the thin wall and can not find a step for that. I looked in Ordered nothing.
I hope this helped!
N/A
Top as in "LID" a seperate part or top as in a compleatly closed body with the hollow inside?
