Creating a porous cone
I'd like to create a porous cone design in solidedge, but am unsure of a practical way to make it porous. My simple design for the structure is attached - a simple cone.
But rather than being a solid cone, I would like it to be porous, having 'pores' of diameter 1mm.
This would be like some porous materials you get (http://en.wikipedia.org/wiki/Metal_foam). Any idea how to create a porous structure?
Thanks for the help!
Charlie
Re: Creating a porous cone
Esteemed Contributor
What is your goal of having it "porous" in Solid Edge?  Mass, visualization, mechanical properties?  All of this can be done creating and using the correct material definition.
Production: ST9 MP10
Testing: ST10 MP3
Hi Ken,
Thanks for the reply. The idea is to 3D print the porous cone structure, so the pores do have to be physically there in the design - not sure if changing the material properties would do this?
Charlie
No, the material properties would not do this.  You would have to model this, but I would talk to whomever is doing your 3D printing as pore sizes of 1mm clear of material may not even be doable with many 3D printing methods/machines.
Testing: ST10 MP3
