Cross Hairs Out of 90 Degrees
I noticed on this doc. The cross hairs of 90 degrees. Also, if you notice the part is out of line with all measurements. I seem that I am unable to adjust..
http://screencast.com/t/pzjyiW0rh7
Thank You Very Much
Greg
Re: Cross Hairs Out of 90 Degrees
It has to do with what plane you are locked on to and it's x axis orientation. Use F3 to unlock/lock and specify a new one.
http://Grundey.blogspot.com
You asked this exact question back on September 8th.   Th...
That thread, with responses, is located here:
http://community.plm.automation.siemens.com/t5/Solid-Edge-Question-and-Answer/Cursor-Lines/qaq-p/441...
-Dylan Gondyke
