Ctrl+C Ctrl+V Assembly Document
Hello Edge User
One assembly document
Delete active parts
I placed parts with different shapes with the same part name.
It is attached to the existing shape!!!.
(I worked with Ctrl + C, Ctrl + V in the referencing assembly.)
If you rename a part, the same part becomes too much.
Is there any good way?
I've attached one video.
https://www.youtube.com/watch?v=LhlFccRobVY&feature=youtu.be
Betreff: Ctrl+C Ctrl+V Assembly Document
maybe You first try to save the ASM before insert copy
And BTW - I don't think that to have different parts (different geometry) with the same part name is a good and appropriate method.
File names and Document numbers should IMHO always be a unique value.
Wolfgang
Hello hawcad
This problem occurs because of sub-assemblies in separate folders.
Fixed by deleting the file in question from the subfolder.
thank you.
