Custom interface
Hi, i'm using SE 8 at work for a company, they have already loaded their settings on the program and now i'm personalizing the interface but i found a problem, i have some tabs (family of parts etc) on the left and i want to move them to the right and move the prompt bar but i can't see the blue snap points (the arrows with a little window inside on every side of the work area) when i move the tabs so i can't "snap" the tabs in place.
Here's a screnshot of my SE at home, as you can see while i'm moving a tab on every side a blue arrow appears to let me snap the tab in place.
How can i activate these things?
Re: Custom interface
I've heard it's a problem with MP2. What are your MPs at work and home?
Bruce Shand
ST10 MP7 - Insight - Win10 - K4200
I can confirm, I see this condition with MP2.....it is a known regression, and a fix is touted to be coming.
>> http://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/No-Pane-Snap-locations-on-ST8-MP02-w... <<
Solid Edge ST10 [MP8] Classic [x2 seats]
At home i'm using the student version (i used it to learn to use SE) 108.00.00.091
At work i can't remeber, this friday i'll check which MP they have.
Another strange fact is that both PCs have Win 7 64 bit with the Aero theme activated and as you can see from my screenshot the top bar of SE (where there is "Solid Edge ST8 - part..") is semi transparent like every window in Windows 7, instead, on the work PC the SE window is like classic Windows (not trasparent) and it is the only software with this problem.
Hi there,
Just so you know, your Student Edition at home will actually accept maintenance packs, should you wish to apply them to match your work place setup.
More than match the MP version i wish to fix this problem with the version at work...
Also i think that the MP of the work PC is one of the latest...
(the PC is 1 week old and SE too)
I didn't mean to kudo that but I've been told that MP3 s/b out in a matter of days.
Bruce Shand
New to ST8, we can now uninstall the maintenance pack separate to the Solid Edge application....so if you have MP2 installed at work, then uninstall it. Now, I am assuming you do not have MP1 installed prior, [if you do, then you are finished] you'll need to download MP1 and install it.
I don't find that pane docking an issue, as I had all mine sorted out prior....but totally understand the frustration this would cause.
Also....if you manage to get your UI set out how you like it, [at home, or at work] you can copy/paste that from one system to another.
You'll find the files here... C:\Users\YourUserNameHere\AppData\Roaming\Unigraphics Solutions\Solid Edge\Version 108\  ...look under the "Customization" folder for your "New Theme"
Sorry i hadn't understood, i'll try to install the MP1, thanks Smiley Very Happy
Sorry for ultra late reply, this is the license on my work pc:
