Custom properties - filtering, searching
Hello
I modified propseed.txt file.Added some custom properties to part files.
Does anyone know how to add, create  any filter in asembly file to search files according to specified custom properties?
Marcin
4 REPLIES 4
Re: Custom properties - filtering, searching
Are you talking about the Part Library Search tool used when adding files to the assembly, or the Query tools to search for parts already in the assembly?
http://Grundey.blogspot.com
Hello Grundey.
The second one- query tool to search parts ( with custom properties) already in the assrmbly assembly.
EXAMPLE: searching all parts in assembly with custom property "milling", " turning" , "to purchase" " vendor name" etc...
Marcin
In ST8 and prior, it can be done, but it's not entirely obvious. To do it, simply type the property name in the Property field when defining the query:
In this example, I added a "to purchase" property.
In ST9, it will be a little more obvious because we have added an explicit entry called "Custom File" which will add an edit field to define the property name when selected:
Hope this helps,
Greg
Hello Greg
Thanks for help.
It works like you described
Marcin
