Customised drawing table
table.pngHi All,
sorry for repeating the issue but I have got question how to set up the drawing table to fill in automaticaly the boxes in the drawing table.
I mean, the Date box - to fill the date
Description - to put the file name in
etc.
When I am creating the individual drawings now I have to fill all these boxes by hand which it is time consuming.
Thank you,
Arek
14 REPLIES 14
Re: Customised drawing table
te.JPGte1.JPGproperty list
from here you can get all the properties ... and use it for your DRAFT .....
MfG -
Viv
if You take a look into the DIN metric Draft template and inspect the drawing title block You can see how there the according properties are brought into the draft header.
As mentioned You can use any property which will be found either in the 3d mdeol file or in the draft itself.
Wolfgang
Hi Black-Bird,
can you tell me please how to set up the actual drawing scale ?
I am trying to do it as sown on attached pic but it is not working.
Thank you,
from the pull down menu select draft view (hope its correct in English) ... there you can select Primary scale or secondry ...
MfG -
Viv
Honored Contributor
Honored Contributor
I uploaded my draft file yesterday in the thread "A few questions about my draft file" you can look at that draft file and see what I used to automate the title block.
Hi Black-Bird,
I am doing this regarding your instruction but it is not working unfortunatelly.
Any clue ?
thank you
Arek
It should .... work ... if not .. take small vdo ... and upload maybe the guys here can help you more ...
MfG -
Viv
just uploaded the template file with not working Primary scale command.
Can you help me understand the issue please ?
thank you,
Arek
sorry I got ST8  Smiley Sad
MfG -
Viv
