Cut Command By Mistake
Working under synchronous part set the save command deleted? part of the protrusion cut.
I may know what has happened... Seeing the doc. I may have hit the cut command. I've looked under for active inactive file nothing, tried under the protrusion nothing.
I am sending a video to illustrate this issue.
http://screencast.com/t/4LeviRgGd5g
Greg
Re: Cut Command By Mistake
Greg, when you transitioned to Ordered it applied all the Ordered features.  Cutout 28 is most likely the reason you are getting what you got.  Try Suppressing it.
http://Grundey.blogspot.com
