Cut command now a two step process?
Please forgive me in advance if my terminoligy is a bit off.
Suddenly my cut command is asking that I extend into 2 different directions instead of one.
I want to cut to a finite depth and while the first step allows me to do so, it now asks me to extend in the opposite direction. How can I turn this off and go back to the normal way of cutting? I have no idea how this got turned on.
 Untitled1.pngfirst stepUntitled2.pngsecond step
5 REPLIES 5
Re: Cut command now a two step process?
Turn of the non-symmetric extent option.
Thank you. That worked.
Betreff: Cut command now a two step process?
Hi @dcoleman
You nearly can answer Yourself when looking onto Your pictures.
You can see the reason for that, and this is that You have turned on the  "Non-Symmetric Extend" option!
Just turn it OFF and everything will work as before!
Wolfgang
Thank you! I swear I clicked that intending to turn it off. Maybe I was trying to do it too quickly and overlooked it.
Right under my nose!
Hello @dcoleman
Please mark one or more messages as 'accepted solutions'
It will make easy for users reading this discussion in future to find out the solution quickly, instead of reading through all messages.
Thanks.
