Cut length changed when frames mirrored or patterned
Hello All,
In a steel truss, the inner web frame members are same. When trying to mirror similar frames or making pattern, the new copied frames have different cut length (varies from 2 to 3 mm from actual cut length). So when the part list is made in draft, they are all showing in different rows. But all those web frame members should have excatly same cut length.
Can anyone please suggest a solution?
Aslam
