Cut view in Simulation
Hi everyone,
Working on the design of a part, I need to study its mechanical behavior and find the way to copy the deformed surfaces.
The simulation works but I can't find the way to copy the deformed surfaces :  I tried to cut the simulaed part butI don't find the button to do it.
Can you help me please ? I'm working on SolidEdge ST9 Smiley Happy
Unfortunately, I can't share the part because of the confidentiality.
Aymeric
Re: Cut view in Simulation
Siemens Legend Siemens Legend
Siemens Legend
Aymeric,
you can use 'view/clip' (ctrl+d) to apply a section to your model.
I hope this helps.
Good luck /Ulf
Siemens EMEA GTAC Support
Hi Ulf!
First of all, thank you for answering Smiley Happy
I already tried the View/Clip. It cuts my part but cancel the deformation as you can see : Smiley Sad
What I need is to see the exact deformation of a section. Another solution could be the transformation of the deformed part into a new part, but I don't think that it's possible.
Do you see what I mean ? Thank you again for your help Smiley Happy
Aymeric
Siemens Legend
Ahh, now I see.
Enhancement request 7237579 exists for this. You should add your vote to this ER (via your reseller?)
Thank you for helping Smiley Happy
I close the topic Smiley Happy
