Cutting Plane Properties
OK. I am sure this is simple but...in Draft, I have my cutting plane properties to use a 0.35mm line. But when I add a cutting plane it comes through at 0.46mm which is often much too thick. Any idea of how I can get it to be 0.35mm?
I can post some pictures if that helps.
Peter Smith
Re: Cutting Plane Properties
Hi @Greybarn Create a new drawing view by modifying the size of the line, check the video.
Thanks.
(view in My Videos)
Regards.
Hi @Greybarn
as shown by @Kanwulf video You can change and define  the style of every object in Your draft.
But to get them also for every new drawing You will create, You have to define that inside Your templates rather then changing it again and again.
So define Your wanted styles in Your template draft and from than on it will be no doubt that your drawings will look like as You expected them to do.
Wolfgang
Thanks for that. I was able to get that to work for me.
Peter
