DIMENSION TEXT
Not applicable
Can a dimension text be edited? I am new to SE and can not find a way to do
this. Then I wind up deleting it and putting a callout there instead. That
is no longer tied to the diameter of the hole. Many times I need to say 2X
in front of the diameter or something like that.
Thanks in advance for any help.
Smoky Rick
Re: DIMENSION TEXT
Not applicable
Select the text then select the select the Prefix button in the Ribbon Bar.
See attached image.
David
"Smoky Rick" wrote in message
news:486657e5@bbsnotes.ugs.com...
> do
> That
> 2X
> Smoky Rick
